You hear movement beyond the pipes, your objective is still incomplete, and the last container in Spaceport is sitting just around the corner. That is The Clean Dream in Arc Raiders: a quiet maintenance assignment that turns every hallway into a risk calculation. Apollo sends you to search four containers, monitor a filtration system, inspect purification equipment, and photograph blueprints, with useful ARC Raiders Items often competing for the same limited time. The mission is easy to understand, but not always comfortable to finish.
What You Actually Need to Finish
The quest has two distinct halves. Spaceport underground tunnels handle the container searches and filtration interaction, while Blue Gate's Maintenance Bunker contains the purification system and blueprints. That split matters because players often treat the assignment like one long scavenging run. It isn't. Spaceport rewards a compact route through connected spaces; Blue Gate rewards careful room reading once you reach the bunker.
Spaceport: Stop Searching Like a Hoarder
The four containers are the part most likely to stretch a run, especially when optional loot starts pulling you off course. Search containers close to your current path, keep track of which areas you've already checked, and leave once the requirement registers. Don't turn a clear objective into a full tunnel sweep. In my experience, the safest loadout is the one that supports a quick in-and-out trip rather than a greedy haul packed with supplies you never needed.
Enter Spaceport with the container count in mind.
Search nearby containers before taking a deeper detour.
Interact with the first accessible filtration system instead of hunting for a perfect route.
Pause after each objective update and listen before crossing the next corner.
Leave the tunnels when the required work is complete.
The Two Locations Demand Different Habits
Spaceport is about exposure, sound, and awkward sightlines. The tunnels can make a short distance feel longer because corners hide both threats and escape options. Blue Gate is more concentrated: the Maintenance Bunker gives you a smaller space to inspect, but that can create a false sense of safety. Use the area comparison below as a mindset check, not as a rigid route.
Area
Main task
Best habit
Spaceport tunnels
Four containers and filtration
Keep moving with a short route
Blue Gate bunker
Purification and blueprints
Inspect machinery and walls carefully
Blue Gate Is Where Players Miss the Point
After monitoring the purification system, don't assume the quest will finish automatically. The blueprint photograph is a separate interaction, and the useful clue is the bunker itself: service equipment, storage details, and records all belong to the same maintenance theme. Check the edges of the room instead of staring only at the largest machine. If you are carrying extra loot from Spaceport, ARC Raiders Loot for sale may look tempting to chase later, but the photo objective should take priority before you extend the run.
The Mistake I Wish I Had Avoided Earlier
Players often spend more time preparing for imagined danger than completing the actual assignment. The Clean Dream doesn't ask you to clear every room, win every encounter, or maximize your inventory. It asks for observation and controlled movement. I could be wrong but, from what I've seen, most failed attempts come from adding side objectives after the main work is already done. Once the blueprint is photographed, weigh the extraction risk honestly. Extra materials are nice; a completed quest is better.
Why This Small Quest Works
The Clean Dream gives Arc Raiders a strong bit of worldbuilding without stopping for a long explanation. Filtration, purification, and blueprints show a society trying to preserve knowledge and basic function after everything became dangerous. Your character isn't restoring the whole world with one bunker visit. You're checking what still works, recording what can be preserved, and getting out before routine maintenance turns into an unnecessary firefight. That modest scale is exactly why the assignment feels believable.
